Husqvarna linkage problems
besterfe
If it is the bit that the wire clips into then that is what it is , a cable clip.
Never seen them for sale at a mower shop but usually available from am auto upholstry supplier
thats exactly what it is!!! have not used one of those in a lot of years.
Is this the plastic clip you’re talking about? Can tell from the picture you posted.
Kohler parts number 47 158 07-S
besterfe
any non standard repair to get this to work with out the retainer?
You could drill the end of the rod & fit a split pin .
Without the plastic the rod will rattle around and make the governor run eratically
