Husqvarna IZ4818 won't start (Kawasaki Powered)
hitmanharleyk
I mowed on Thursday and the mower ran like a champ. Friday I put up a new air filter and pre filter in it and when I went to move it to swap out the blades it would not start. It I give it a short blast of starting fluid it will run for a second or two until the ether is gone. I did clean the inside of the outer air filter cover with some brake cleaner to get the nasty dirt out of it, but I also blew that off with the air hose prior to putting it back on to remove " most" of the cleaner. I toook the plugs out and they looked fine, but didn't smell like gasoline was getting to them.
Where should I start trouble shooting? By it running on the starting fluid it is safe to say it is firing, do I replace the gas line filter or the fuel pump?
Thanks in advance,
Harley
hitmanharleyk
Just disconnected the fuel line from the pump to the motor, pump is working fine.
Think you're going to have to rebuild the carb. Sounds like the main jet has dirt in it.
hitmanharleyk
Job for a shop or for someone like me who grew up on a farm and is pretty handy?
Is it hard to do on this engine?
If you are handy and have patience you should be able to do it. Open work bench with rags spread out, carb cleaner, carb kit and basic tools are all you should need. Just take your time and watch what you're doing.
hitmanharleyk
Handy yes, patience no!
hitmanharleyk
Unplugged the wire on the solenoid and checked it for power, plugged it back up and she cranked right up!!!
Does that mean you got it running?
hitmanharleyk
I did get it running. I mowed this afternoon and after about 15 minutes it cut off again, I unplugged the wire and then reconnected it and it ran like a champ the next hour and a half.
Clean both parts of this connection to prevent future problems.
