Husqvarna HU775H tensioner spring
dme320
New member and I just bought a used Husqvarna HU775H. It was going into gear rough so the first thing I did was take the underside apart around the gearbox to clean it up and take a look. It appears the drive control cable is very loose which I can see how to adjust. The problem I have is that the tension spring was not connected to anything. I assume this is to disengage the belt, but I can't find anywhere to attach it back. Any ideas? Thanks.
