Husqvarna GT52XLG
drg123
Hi,
I'm going to remove my mower deck on a GT52XLG and wondering if it's difficult for one person to remove and install it by myself. Im wondering if it's too heavy.
Thanks
If you down load the owners manual it shows how to remove and install the deck. I’ve done it by myself many times, but it is always easier with an assistant. We don’t know you so it is had to tell you if you can do it yourself. As I’m north of 70 years old it is now harder to get up and down, plus my strength has also gone down hill. I can still do it, but takes twice as long.
Get some long 2x4's and slip them under the deck before you remove he mounts
then slide the deck out with the timbers acting as rails
poncho144
Had the deck off 3 times on a 2018 TS354 D. First time was the winter of '18 and I was 78, piece-o-cake. Second was in 2020, 80th birthday, couldn't believe how heavy it was. The last time after a stroke at 83 it was worse than hard. Now, since hip replacement, just can't wat to wrestle dat SOB again!i
