Kind of lost on this one. Been searching quite a bit on this topic (blower is for residential use). All I can find is that the 350bt has a slightly nicer harness. Second, many people mention that the 350bt has lower MPH but higher CFM because it uses bigger piping. However, according the Husq's own site, that isn't the case:
150bt
HUSQVARNA 150BT - Blowers
710cfm (in housing) @ 251mph
?? - in pipe
350bt
http://www.husqvarna.com/us/products...specifications
692cfm (in housing) @ 180mph
494cfm - in pipe
Can someone explain to me why the 350bt cost more or am I misreading the spec? Does the "in pipe" CFM rating matter more? There is no in pipe spec for the 150bt?
Thanks in advance for any help!
150bt
?? - in pipe
350bt
494cfm - in pipe
