Repairs Husqvarna 6128 B&S floods under load
Sanibel58
Husqvarna 6128 B&S floods under load, I've changed battery, spark plugs, air filter. will start at low idle, when I increase throttle the engine floods out. When I shut off fuel to engine the engine will run under load until fuel in line runs out. can someone help please
B&S model xxxxxx, type xxxx, trim xx & code number.
Model - 966613101 maybe 966613102
I don't know what trim is or code number
