Battery not charging on this unit. charged battery overnight. Voltage is 12.3 VDC when tested with voltmeter. Machine starts right up and voltage still shows 12.3 VDC when running. How do I tell whether the problem is Alternator or regulator?
:welcome:
How you test the engine's alternator will sort of depend upon something you know but we don't
The engine make & model number.
