Husqvarna 125 B
Butch1957
On this blower, can someone tell me how the fuel lines hook up on the carburetor ( which lines go where ) and on the primer bulb ?
I kinda took off to replace and I am confused now.
Any help / input will greatly be appreciated.
SKU 952-711-925 24761-01679
:confused2:
Yea, That picture do you any good?
The small hose on the bottom of the carb hooks to the fuel filter.
The larger hose hooks to the top of the carb then hooks to the short nipple on the primer bulb.
Then the final hose hooks to the long primer nipple and is routed to the fuel tank.
The fuel is sucked through the carb into the primer bulb and discharged back in to the fuel tank.
