So we are having a difficult problem with our Husqvarna YTH28V48 Riding Mower. This mower has had a few problems this summer. One being that it would only operate in full choke. Lowering the choke would cause it to idle and die. Second, the battery was having issues frequently. The problem that we are facing now is that the mower is not starting. The concerning part is that when turning the key the mower will turn and make a knocking sound. We cannot get it to actually start. This started after a normal mowing operation when the mower suddenly stopped. No loud sounds or anything. It just stopped liked when you turn the engine off. What do you suggest we check to try and solve this problem. We hope that it isn't something deadly to the mower. Oil level was just below the safe zone. I should have changed it the starting of the summer. Instead, we ended up just topping the oil off. I know, not a good thing.
