Husq zth 5221 wiring
Timtech
Have an issue with grounding of coils. Anyone know where I can get a schematic? I’ve checked the seat and parking brake interlock switches but still can’t get the ground to clear. Thanks. Tim
From Husqvarna on the web
They will either be in the parts book ( usually)
or
the Owners manual ( occasionally )
Generally right down the back.
Check the serial numbers as wiring changes during the production run.
Timtech
or
Everything I’m seeing online is block diagram not schematic. I’m trying to ring out point to point and these don’t help. I’ll keep searching but thanks for the reply. I’ve disconnected the ground wire to each coil so I can mow but want to fix properly. Seat switch and park brake work clean (via dvm) but I’m not certain what other interlocks there are in the circuit. Great forum!
Tim
Page 20 & 22 of the owners manual.
They split the diagram up for some strange reason
So print them both out and cut along the line with the plugs then join the two sides together.
A silly way to do a circuit diagram but the information is all there, you just need to know things like the pin out for a standard relay
Switches are shown with their connections so I can not see a problem following the circuits.
Timtech
Thanks. Got it.
