Checked belt, pulleys & debris, All is fine (or clear). Suspect the trans as I loose traction only after running for a while. When 1st started up, will go up/down low grade hill fine, but after running a while it loose all traction on same hill. Feels like the pedal lost connection w/ trans somehow. After a few hours, mower will go again with same problem as above. Sent email to Husq help center 5 days ago but no response. they claim to respond in 1-2 biz days.
