Mower wont move drive belt is tight fan is spinning. The small lever in the back to disengage to free wheel makes no difference where it is always free wheels. Its connected and moves the rod back and forth. Don't know where to go. belt
Rod at back should be pushed all the way in, Safety First- everyone out of way, remove deck, scotch front wheels, jack up backside of tractor carefully, crank it up & see if wheels turn. Let us know what you find, thanks. Post model & serial numbers from tractor data plate or sticker.
http://www.husqvarna.com/ddoc/HUSO/HUSO2011_NAen/HUSO2011_NAen_YTH20K46_532441457.pdf see page 26, loss of drive.
http://www.husqvarna.com/ddoc/husi/husi2011_naen/husi2011_naen_yth20k46_532446280r1.pdf check out pages 8 & 9 in this parts manual, with deck off, what kind of shape is drive belt & 3 idler pulleys in? you will need to remove idler pulleys to inspect bearings for being rough, dragging, etc. When replacing parts always use OEM parts. Let us know how it goes, thanks. how old is tractor, year?
https://www.tufftorqservices.com/EnvEEdefault/FlatHTML/TransaxleIdentification/LT_K46.htm this is your transaxle K46, thought I'd post this in case you want to read up on it.
mechanic mark, seems like you have him headed in the right direction if he will follow through.
Wonder if he removed the deck?
thanks a ton guys get to it this weekend
Thanks to all of you who helped. CANT BELIEVE ALL IT WAS .................broken keyways!!!I thought the tranny was shot!!!
