stagefoursurvivor
- Jun 23, 2014
- 1
- 12
This is ridiculous! Used it last week after dry lubricant treatment and now it won't start AGAIN.The HZA has the same autochoke design as your VKA.Maybe you should go for the Toro. :tongue:
The HZA is, in my humble opinion, a nicer machine than the VKA due to the hydrostatic transmission and controls, but this is a personal preference. You may like the SmartDrive or Toro controls better.
If you do go with the HZA, the dealer should check if the serial number is in the affected range documented in the service bulletin. If it is, the dealer should then determine if there is an issue with the autochoke or not, and update the parts if needed before you take delivery.
It begs then why not just let them repair your VKA if you like it otherwise? Hard to imagine you are so desperate to get you lawn mowed you'd decline a free repair and spend more money on a new/different/untested mower just because you don't want to wait 14 days. I'll bet you could pay somebody to mow your lawn while your Honda is repaired, for less money/time/effort that it would take for you to trade in your current Honda for another mower.
Comparing auto service turn-around time to lawn mower service turn-around time is apples/oranges. I will guess the dealer is "2 weeks out" on ALL brands of mowers, including Toro.
What does Honda do for a repair? Do they replace the entire autochoke assembly or just dry lube the defective one?
