HRX217HYA - new carb, still will not run
New carb and new gaskets fixed my problem. Yours sounds a little different. I would check fuel delivery.
Thanks, but I really don't see much to the fuel delivery from the tank through the valve into the carb.
The problem seems to be simply that Honda has a manufacturing defect in the idle mixture under no-load, and they refuse to fix this problem under warranty. And there's no adjustment set screw, probably as required by EPA.
