I'm needing a new axle for my HRX and by looking at the schematic sheet,it looks like you have to buy the transmission assembly to get the axles......the problem is that the grooves on each of the axle where the C-clips behind the pinion gear is wore out and I have lots of side to side slop in the axle....2014 model HRX with estimated 700 hours....
