Bphillippe
- Apr 29, 2022
- 2
- 3
I have an Honda HRX 217 that had a bent shaft. Replaced the crank shaft and put it back together and when you pull the cord without the sparkplug in it sounds good, but with the sparkplug in, it makes a metal tapping sound on the compression stroke. Can't quite locate the sound location. Any ideas. I really don't want to reopen the engine again. But I will if needed.
