I bought an HRR2167VKA mower at Home Depot last year. I use it about 10 hours a week. About 90% of the time when I pull the mower backwards the rear wheels immediately and completely lock up. It's fine going forward. Any advice? Thanks!
I have a Husqvarna Riding Mower YTH22V42. I changed the Vbelt with the parking brake on. Returned the deck with
new belt installed. For some reason the rear wheels locked up, after releasing the brake. Any suggestions
A common cause of resistance when rolling backwards is dirt/debris/drag on the rear axle. Here's a drawing showing all the parts; suggest disassembling as shown, clean and lubricate.
If the problem persists, could be a damaged drive clutch cable, but try the clean-up procedure first.
