Hi, I have an HRR216 S3DA MZCG-6078970 basic lawn mower that I picked up at the curb. After getting it to start again, I realized that it doesn't roll back on its own and doesn't go forward under load when the self-propel system is engaged. I've followed a few videos demonstrating how to take the rear end apart and clean it thoroughly, including taking the snap rings and pinion gears out, carefully cleaning and sanding the rust from the axle, then reassembling it. However, it still doesn't go back easily. I'm wondering what the next steps would be?
Even when suspended off the ground, the tires don't really spin as freely as I feel like they should. It goes forward in all three gears when I suspend it off the ground and engage the self-propel system, so I don't think it's the belt or the transmission. The height adjuster also now moves freely as it should. I also don't see any way to adjust the cable that engages the self-propel system arm, thinking maybe it wasn't engaging the belt fully.
I'm also now able to turn the axle freely by hand. I've also confirmed the pinion gears on both sides are in good shape, as are the gears in the wheels, so the transmission is definitely engaging with the wheels.
Could it be the driveshaft bushing? There seems to be a bit of side-to-side play in the wheel. I've put together a 60s video showing this problem:
drive.google.com
Here's a link to the parts diagram for the rear wheel
How smooth does the axle where the bushings go really have to be? It didn't appear like the axle was very bad, so I didn't remove it entirely. I only cleaned it and sanded it with 220-grit with it still in the chassis.
Ideas are greatly appreciated.
HRR216-real-wheel-play.mp4
