Hrr 216 height adjustment axle
ihor hnytka
Does anyone know what keeps the height adjustment ankle from coming off the holder. I noticed on a parts schematic
That there is a 25 mm c clip. Is this clip used to keep this axle on the holder? Thanks, Ihor
robert@honda
The HRR216 comes in almost a dozen flavors; got a serial number off the back of the mower deck?
Does yours have a single lever for the rear height adjuster? What part(s) shown here are giving you trouble?
mechanic mark
Click on members top of page & send robert@honda your message with all numbers from mower, not just HRR216. Example: HRR216VK9A MZAMXXXXXXX. Click on R's then page 97 bottom of page.
ihor hnytka
Part 1 axle detaches from part 7 Holder causing one side to drop
ihor hnytka
Will look up model numbers
BlazNT
Two part number 7. Which one do you mean?
robert@honda
Ensure the bolts holding on #7 are secure, and there's no damage to #7 or the hole in #1 where it fits. Inspect for any loose fit, sloppy fit, bent or damaged parts.
