HRM215 Hydrostatic Transmission fluid change
Ponz
Robert hasn't been seen here for a couple years now.
Just keep adding a bit at a time and check the level each time you do. You'll eventually get there.
Thank you.
Is it OK to siphon out all that I can and replace with new? Will there be any cavitation issues? How much should I expect to pull out?
Oh! One more question. So far, the dipstick reads just touching the wide portion of the stick. Will overfilling cause any damage?
Thanks again,
Ponz
olgeezershonda
Sorry. Those are questions I can't answer for you and I don't want to be the one to screw it up for you. I'd contact a local Honda Power Equipment dealer and ask them. If you do be prepared to give them your mower's complete model and serial number.
