rainman1442
- Jul 17, 2013
- 10
- 24
I have an HRC 216 and the wheel adjuster in the front has become difficult to adjust. The bar that runs between the two front wheels moves up and down as I adjust the wheels. On my other HRC 216, the bar does not move when adjusting wheels. I checked the wheel...it was tight. I removed the wheel and checked the bolt that attaches the adjuster to the frame and it was tight too. I'm not sure what is causing the problem. Does anyone have suggestions or have had similar problem?
Thanks.
Thanks.
