Good Morning Folks - I have some new information to add, so I thought I would start with a clean slate. For those just arriving, lost all the oil at once. Forum suspected that it was the lower seal. As is evident in the photos, the oil that I added is dripping from around the roto-stop, not the seal in the middle. Someone was kind enough to suggest two other parts to consider. My questions for the group. First, could it still be the seal if it is not leaking there? Should I remove what is left of the roto-stop and try adding more oil? Do you think it is likely to help pinpoint the problem? If not the seal, how likely is it that the leak could be one or both of the other parts as suggested in the photo below? What are those parts and does it require the bottom of the motor be removed? Thanks in advance.
Finally, is there a better way to post pics? I've used photobucket. Is it working sufficiently well?
Mike
Mike
