No idea what your monitor shows for a subject of this thread but mine clearly states:
QUOTE: How to tell when the air filter on my riding mower needs changing?
If you can afford a 4 ft. length of clear plastic tubing from Ace hardware you have the most expensive part of a water manometer. Other components would include a few table spoons of water and a drop of food coloring of your choice for easier visibility.
Other uses - check crankcase vacuum on your pickum up truck / car, set the gas pressure on your furnace or hot water heater just to name a couple.
