how to replace broken left rear wheel height adjuster plate? HRR2165VKA
jharris18
I'm a newbie to doing this myself but am determined to do so. Got the wheel off...but am now stymied by the pinion gear and all the things that still seem to lie between me and the height adjuster plate (the arm that sticks up and that you pull to adjust).
I have the replacement parts in hand and ready to go. but how do it get all this stuff off to get to the problem?
This is the model with individual height adjusters on all 4 wheels. thanks!
Need the pin washer tool I forgot the name someone else can say it.
Get new pin washers and when you take everything off lay them out in order and replace your part clean and regrease all the parts put them on excatly as you took them off. Pay careful attention to the gear and key they fit two ways a wrong way and right way
