cantdw
The local dealers and repair shops are, understandably, too busy to help with what I think is a simple problem. And, there doesn't appear to be a match online (Youtube) for how to replace this spring. There can only be two ways, right? But what end up happening is the idler pullet snugs up against the drive wheel and stops the wheel - and hence the drive belt - from spinning - and the forward motion stops as a result. There is a small hole in the deck where one end should go, and a slot on the armature attached to to the Idler Pulley. But the spring actually brings the two pulleys CLOSER together - rather than adds tension to keep them apart and the belt taut.
Any thoughts are appreciated.
Tom... cantdw@gmail ...
