How to remove when it keeps moving?
Scrubcadet10
Moderator
Staff member
What piece of equipment is this on?
If you have a large pipe wrench, use that to hold the adapter. No pipe wrench remove the spark plug, set the piston at BDC, stuff cotton rope into the cylinder and turn the adapter until it stops. Make sure you leave some rope outside the engine so you have something to grab when you complete the job.
Can8dns
It’s on a Honda push mower. Trying to remove it causes the heat to turn under the mower
Can8dns
It just keeps turning. An impact wrench would only make it spin
Divot
Actually it doesn’t work that way. You can’t take a mower blade off without holding or wedging the blade to keep from spinning but with an impact, one doesn’t have to even hold the blade, for example
Fish
Folks often think that an air wrench or drill is an impact, when it is not.
Here is a video I made to show folks how to remove a flywheel.
Can8dns
It can off with an impact wrench. Thank you!
