GREETING,
I HAVE REMOVED THE BOLT HOLDING THE TIRE AND TIRE RIM TO AXEL SHAFT, BUT THE WHOLE TIRE AND RIM WILL NOT FREE ITSELF WHEN I PULL ON IT FROM THE LAWN MOWER. EITHER I AM TOO WEAK OR THERE MAY BE A PIN HOLDING IT ON IN THE BACK SIDE OF THE TIRE RIM ITSELF. I NEED TO PUT A TUBE IN THE TIRE AS IT CONSTANTLY GOES FLAT. THANKING YOU IN ADVANCE.
CHAPANOKE
CHAPANOKE
