robert@honda
- Nov 2, 2011
- 97
- 1,791
Great tips and techniques for getting the best results from your Honda Mower; from Honda's Service Publications group:
The Blades
Before mowing, always check the condition of your blade(s). A dull blade will tear the grass and require additional power from the engine. Also, the lower blade on twin-blade models works like a fan. If the raised or lift area of the blade is worn, air flow will be reduced and cutting performance will suffer.
Be sure to refer to the owner's manual that came with your lawn mower for specific instructions for inspecting, sharpening, removing, and reinstalling your blades. Always use the correct blade(s) for your lawn mowers' model. Honda blades are carefully designed for specific models. Don't use after-market or "universal" blades. Doing so could also result in poor cutting performance and more importantly, an unsafe condition.
How Often to Mow
If you look closely, you'll see that most grass has stems and leaves. If you cut off the leaves, you'll scalp the lawn. Let the grass recover between mowings.
If your grass gets too tall, cut it once at the highest mowing height setting, then mow again in two or three days. Don't take off more than one third of the total grass height in any one mowing, or brown patches may develop.
Most lawns need mowing at least once a week. Most grasses should be mowed when they have become 1/2 to 1 above their recommended height. Consult a local nursery or lawn and garden center for mowing height recommendations for types and conditions in your area.
Cutting Width
For an even lawn finish, overlap each mowing swath by a few inches. If the grass is very tall or thick, use more overlap and a narrower mowing swath.
Use Full Throttle
Rotary mowers cut and lift grass best at full throttle. Use full throttle even when the grass is short or thin. To slow the ground speed of the mower, adjust the transmission to a slower speed or push the mower more slowly. Do not reduce the throttle setting to slow the ground speed.
Wet Grass
Wet grass clippings will tend to clog the mower deck, and they will lie in clumps on the lawn. Always wait for wet grass to dry before mowing. If you experience clumping, use a leaf rake to remove the clumps and prevent brown patches.
Dry Grass
If the ground is too dry, mowing will stir up a lot of dust. Besides being unpleasant to work in, too much dust will clog the engine's air filter. To minimize dust and fine particles from passing through the grass bag fabric, it is best to mow grass in the morning when the ground is slightly damp and the grass is dry.
Using a Grass Bag
Bagging should be considered where you want the area to be clear of lawn clippings, such as around a swimming pool or patio. Because the grass bagging works much like a vacuum cleaner, the grass bag must allow air to flow through it; a clogged grass bag will not work well. Always empty the grass bag before it becomes full. Wash a dirty grass bag with a garden hose, and allow it to dry completely before use.
Mulching Grass
Mulching cuts the grass clippings into smaller pieces that fall through the turf more easily and decompose quickly. This returns nutrients to the soil and reduces the need for raking, bagging, and disposal. For best mulching results, mow the lawn frequently, cutting off less than one inch of grass each time. During the growing season, you will probably need to mow the lawn twice each week. Reduce your forward speed when mowing thick, dense grass. You can also overlap the cutting swaths instead of cutting a full swath with each pass. This will improve mulching performance and reduce the load on the engine. Mulching requires more attention to operation and maintenance than other kinds of mowing. It's very important that the grass clippings get cut into small pieces and are distributed on the lawn without clumping.
Using the Versamow Feature (HRX models only)
You can use the Versamow feature to take advantage of the benefits of mulching and bagging at the same time. Simply install the grass bag and position the Clip Director in the middle of the adjustment range. Now a portion of the clippings will be mulched and returned to your lawn to provide additional nourishment and a portion will enter your
grass bag. Simply move the Clip Director in each direction to achieve your desired results. When mowing thick dense grass, you may need to open the Clip Director farther (more bagging) than you do when mowing thin grass.
Mowing Pattern
Use different mowing patterns to train the grass to stand up straight and prevent tire tracks or grooves from forming in the lawn. Alternate between horizontal, vertical, and diagonal patterns to get the best cut quality. See example A.
The most common cut quality complaint is a trail of grass clippings that collects on one side of the mowing swath. This problem can usually be prevented by following the mowing tips previously mentioned. However, if the problem persists, use a circular cutting pattern and overlap the previous cutting swath by a few inches. If a trail of clippings is forming on the right hand side of the mowing swath, use a clockwise pattern. If a trail of clippings is forming on the left hand side of
the mowing swath, use a counterclockwise mowing pattern. See example B.
The Blades
How Often to Mow
Cutting Width
Use Full Throttle
Wet Grass
Dry Grass
Using a Grass Bag
Mulching Grass
Mowing Pattern
