I need to know how to fix the charging system on a 1992 year 721grasshopper with deck out front. The charging light(discharging light) will not go off. It has a 21 hp kubota diesel block with gas heads( if that makes sense). The engine looks like the 20 hp diesel engine. I have tried replacing the blade fuse on the right side of the seat, and even the voltage regulator. I think the generator is putting out but am not 100% sure. How can I tell? The only post on the generator has 2 like size wires coming out. Need some INFO. Thanks
