SidecarFlip
- Aug 21, 2018
- 282
People run the bags off old lawn mowers and then sell them... Always expect to replace belts, idlers, spindles and other consumable parts. Belts especially only last a short tome.
I honestly always feel I can do most things as long as I have some decent instruction, and especially a video. How can I tell if the bearings are actually bad? Will there be an especially noticeable wobble? How hard is it?
Spin them by hand and if you hear any noise it's bad or on it's way out.... They are supposed to be super quiet........ ~!~!
Good luck with that in Illinois..... Best thing you can do is add Marine Stabil (Blue).
If you can't find a grease fitting on the pulley, don't lube it. It probably has sealed bearings. You could slop oil on that kind of pulley until you're blue in the face and none of it will get to where you think it should go. All you'll accomplish is getting oil where it shouldn't be.
