How often do you replace tires on your mower?
brucesdeere
How often do you replace the tires on your mower? I have never yet on mine and I'm just wondering if it is something other's do regularly or not.
KennyV
Mower tires generally dry rot from age and still go for years...
Unless you are mowing on steep hills where you are faced with a roll over, people usually run mower tires till they fall to pieces... :smile:KennyV
CQ_DX
We see machines here with varying degrees of tire wear versus equipment age and their use.
Here are some of the variables:
Mower type - walk-behind, tractor, zero-turn.
Commercial versus residential.
Operation in all weather conditions - wet (tire slippage= increased wear) versus dry conditions.
Slope of terrain.
Terrain Type - sandy versus dirt versus lush sod.
Amount of asphalt or gravel or other abrasive surface the machine turns around on (as with a Z-T or tractor).
Other uses of equipment besides grass cutting - snow plowing, earth moving/dirt/gravel pushing/grading/tilling, power brushing, etc. (usually tractors, sometimes Z-Ts).
This is difficult to analyize without like metrics.
brucesdeere
Thanks for the answers. My mower is a bit older and the tires seem fine for what I do, but I just wanted a second opinion to make sure I was on a similar page as everyone else.
noma
Brucesdeer
Hi i dont think i have every changed the tires on my riding lawn mower , i don't think i have every wear one out and i use them for a lot of years. Over the years i have gotten a flat tire and sometime depending where the hole or where the repair need done just replaced the tire because it can't be repaired.
abeja_reina_1989
I have had my mower for many years now and have never had to change a tire. However, I think it's due to the fact that I don't put much use on it. I got pretty lucky with a flat lawn :biggrin:
Manny
That's just something I never think about! I guess I would change them if the lawnmower wouldn't move because of a tire issue.
mois25
I would change mine if the mower showed signs of immobility but I guess that depends on the wear and tear rate. There are more useful parts like blades to regularly watch out for, lol.
Stevie-Ray
I've seriously only had 2 mowers. Had a flat on the first which was second-hand to begin with. It's the only tire I've ever replaced. That one was the only one that wasn't bald when I put the mower out to the curb.
