How much PSI
loganmower
I just got a new grasshopper and has tires i have never used, so i have no idea what psi i should put these tires to? and also do you lower or higher the psi when conditions change(wet, dry, ect.)?
Carscw
They look just like the super lugs I use.
I run 8 psi because I do hills.
For flat ground and small hills 10 psi works good.
Yep when I had mine I run them a couple psi under what the tire said because they are so stiff at the correct psi they would beat you to death.
de dee
the tire presure should be on the tire ,. I have 23.5 x 10.5 x 12 inch rear tires and it says 10 lb.s on the tire ,.
Carscw
I believe it will say MAX psi 10
