How much grease
Bhauck
Hello, I’m in the process of putting back together a transaxle from a stx38 yellow deck. Was wondering how much grease i should use. I’ll be using corn head grease 14oz tubes. I totally cleaned the transaxle, so I’m starting fresh.
Than you
Brant
Okay first input shaft bearings and areas should packed with grease. The axle end bearings needs packing. And the pack upper case beveled pinion gear and lower
case housing assembly with 638 g (1.406 lbs) of grease. 1.6 tubes of 14 oz grease tubes.
