bt3
- Aug 22, 2014
- 5
- 249
I've never measured, but for the most part I set the deck only 1 notch down from the highest setting possible in the summer months.
I'd rather set it lower, but I don't water my grass (not with 1 1/2 acres to water) and the Texas summer heat with little rain means if I were to cut the lawn shorter would deprive it of much needed moisture.
Yep. I do the same thing. One notch below max height in the summer. I'm guessing this is about 3 inches in height, but like you, I have never actually "Measured" the actual height of the cut.
