Black Bart
- May 4, 2011
- 550
I have a 1985 JD 430 Diesel and I have done nothing but put diesel fuel in it for 26 years without a problem.You must be very careful & particular about your fuel... and you will get many thousands of hours with a diesel...
They have no tolerance for gasoline or any drying additive to the fuel... You have to separate the water that may incorporate in the diesel... And you have to have a bit of lube added to today's ultra low sulfur fuel... (2 percent bio is the best for lube)...
With just a little vigilance to fuel you will get incredible trouble free service from a diesel... :smile:KennyV
Before retiring I was in the trucking business for 42 years never had a pump problem.
Think what you may but the pump on my Kubota was either defective or a poor design to fail at such low hours.
My problem with the Kubota diesel was waaay before low sulfur fuel.
On a side note Cummins recommends NOT ADDING anything to the fuel. I have had them run a million miles without rebuilding the pump or the engine.
