When I got a replacement coil for my 5239, it did not have a high tension lead attached, The shop that sold me the coil gave me a piece of HT wire, crimp on lead and a rubber boot.
The HT lead was pushed into the coil where it was pierced by a barb in the bottom of the hole where the HT lead attached to the coil. The other end had an attachment that ripped the HT lead by pierceing the side of the HT wire with a pointed barb. After this, a rubber boot was sliped over the end of the HT wire to hold it to the sparkplug and to help make it weather resistant.
Is this a good way of attaching the HT wire? Is there a better way that would insure a good electrical connection at both ends.
Is there a way that I may check the continuity oft the HT wire without removing it from the coil!
Tia,
Franchi
Tia,
Franchi
