How do you remove the starter gen pulley
jeff
How does one remove the engine pulley for the starter generator on a Cub Cadet 122? The oil seal under the pulley is leaking badly and I need to replace it.
KennyV
You may need a puller... it has a key in the shaft, so it is not a tight pressed on fit, but it may not just fall off after you remove the nut...
You should think of it as pulling the pulley off ...rather than driving the shaft out, (don't pound on the shaft to remove it).
:smile:KennyV
