How do you remove the dash? Ariens 934 series
poncho
I've got to get to the electricals but cannot remove the steering wheel so that I can remove the dash. Parts diagrams show a pin which I have removed, and a bolt down the center of the wheel, which I cannot see. All I see down the center hole in the steering wheel is the top of what looks like a metal bar. I've soaked it with pen. oil but the wheel doesn't budge. Help!
Please post the full model and serial numbers.
poncho
Model 934005, serial 000856
There should be a roll pin on the side of the wheel, remove and the wheel should come off.
poncho
Thanks Rivets...... If only it were that simple!
