How do you adjust the idle speed on a handheld gas leaf blower ?
HarryHarley
  • / How do you adjust the idle speed on a handheld gas leaf blower ?
Thanks... that's cool. So, you just point that "arrow' at the spark plug? How far away can you be before you
are out of range?
MowerMike
are out of range?
Well, the manufacturer says between 4 and 15 inches, but I found that I had to be pretty close to get a reading, 4 inches or less. Maybe mine has a weak battery.
HarryHarley
Oh, forgot to ask. Does it work on diesel engines? If so, where do you point it?
MowerMike
No, it only works on gas engines. They do make a tach that will work on diesel engines, but it is not wireless.
