How Do I Replace a Traction Drive Belt on JD Lawn Tractor ? ? ?
46Ford
  • / How Do I Replace a Traction Drive Belt on JD Lawn Tractor ? ? ?
I have a John Deere LT150 Lawn Tractor w 38" deck and need to replace the Traction Drive Belt. It has a Hydro transmission. I've replaced the deck belt without a problem. However, I've been told by some people that the job is very involved and takes awhile.
Where can I find step-by-step instructions and illustrations for changing out the drive belt? I can't seem to find anything on-line. Thanks for your help in advance!
KennyV
WELCOME to these Forums...
I gave you a good link with pictures at your other post... This is the LT160 but the 150 will be the same.
John Deere LT160 Auto Drive Belt
:smile:KennyV
