How do I remove clutch?
Model numbers would be helpful here. Off all three pieces of equipment. The mower and both of the clutches so we can research things.
Edit: Also was the original clutch mounted with the pulley toward the engine or away?
Ugghh, I got the old clutch off, but my replacement clutch has the bearing upside down and isn't compatible. :rolleyes:
I am shaving the same issue right now. Here is my "new" clutch:
The bearing is reversed from the Warner 5218-222. is there a workaround?
the piece with the flat sides on it in the center with the bolt hole is just pressed in and can be removed with a punch and hammer. The main thing is to make sure that the fingers on the friction disc face the same direction
Dude, you just saved me returning this thing and spending way more money! I owe you one!
