how do I find replacement hydraulic fluid reservoir FerrisIS3000Z, Kawasaki
Marlebone
I have a FerrisIS3000Zxk27/61 seriel 3752 with a cracking hydraulic fluid reservoir. Does anyoneknow the capacity of this container? I would like to replace it but the ones I see offered are much smaller.
WOW $503.00??? Really?
Is this nearly the same thing but different hose nipples? You can add those for cheap at any hardware store.
Hi Slomo,
The blow molded white plastic material and wall thickness of the material would not hold up for any length of time. White plastic fails with UV light, heat and extreme cold conditions in a very short time.
Example: I have older riders with the original "black" ABS tanks that are over 30 years old while all of the "white plastic" ones have long since crumbled to fragments.
I don't agree with the excessive cost of the OEM, but that is what the industry has become. Parts are exceedingly high to intentionally steer consumers toward buying new replacement equipment.
A complete cheap push mower can cost $300.00 dollar, but the replacement engine alone will cost $450.00 due to the mass manufacturing of "whole goods"/ complete mowers.
The manufactures are not interested in making/ supplying individual replacement parts or supporting repairs of any kind, there is no profit in that approach. Even the aftermarket suppliers have jumped on this money-making opportunity.
Look at the over view at the bottom of the picture. Says HDPE plastic and blah blah....... Resistance to most chemicals. For 20 bucks he could buy 4 of them and still make out. It just holds hydro fluid. Not the space shuttle.
Of course if I did this it would leak hydro fluid causing a fire burning the mower to the ground.
I like the footnote "must be ordered from the factory....". That means they will take your money while they hope the factory has one.
