Recently bought some Greenworks 40V GMAX tools then found this forum yesterday while searching for pricing / reviews of their 40V Self Propelled 21" mower. I then posted in the "Welcome to the Electric & Battery Operated Equipment Forum!" thread as my into.
Anyway, I then stumbled upon your thread here with the GEN 1 battery problems. As I stated in the other thread, I bought 3 GW tools that came with 4Ah batteries … one of them however came with the WRONG battery, it for some strange reason came with a GEN 1 4Ah battery # 29662. Tool was purchased from HomeDepot.com and it shipped to me from a HD warehouse in Arizona … there was no indication that it was a return or box had been opened and re-sealed, so this battery had to be a factory mistake.
I contacted GW and they sent me the correct battery, so I've now got this brand new GEN 1 battery sitting here that I have absolutely no use for.
This brand new 29662 4Ah / 146Wh Battery has a 12/13/16 date code. It is externally the same, but the terminals are arranged slightly different so it will not click in to a GEN 2 tool, so I can't "run" test it. It displays 4 bars (fully charged) and checked the voltage per MowerMike's post and it shows 30.45V between "+" & "C" and 31.17V between "+" & "ohmega" … quite a bit higher readings than the "approx. 24V" he stated; whether this is good or bad I don't know. I had checked it prior across the "+ & -" terminals and found it strange I got just a small mV reading, so I was happy to see this thread showing the proper way to test it.
So, do you have any interest in this battery ?? Just as you have done, I searched to see what this battery sells for and saw it is around $114.00. I had recently bought a brand new compact 2.5Ah GEN 2 battery from a guy that was parting out a kit on ebay. It regularly sells for around $100 and I got it for $67 delivered … would this be a fair price ?? Let me know, probably can't post pics being a new forum member but could e-mail you some.
Thanks,
Doug
