I was given a Greenworks 25292 cordless mower and a pair of Li-Ion batteries + charger, but the mower does not work. I charged the batteries before trying, so the question is if the problem is with the mower or with the batteries. Each battery has 4 contacts and I tried measuring voltage between each pair using a multimeter. For most pairings I got 0, for one of them I got a number around 13. Does this mean that both batteries are bad? Did I measure correctly? Can a battery like this be tested using a multimeter? Thx!
