I’ve purchased a new (although 2023) Toro Titan 60in ZT with Kohler 7000 series 26hp engine. Hour meter showing 0 hours even after running engine for 20 min or so. I then figured it might only register time with the blades engaged which is the case.
Question is does an hour meter that only shows time with blades engaged really represent the time on the engine?
I figure my old Bad Boy ZT with 1200hrs had at least 100hrs without blades engaged from pulling a sprayer, spreader, aerator, commuting etc. Looks like the meter has 3 terminals but plug from mower has two female connectors.
