dull blade
- May 27, 2022
- 2
- 5
I have a 2008 Lazer Z that the hour meter stopped working, I checked it with 12 supplied voltage and introduced a ground, it stated working, I did my homework and read about the oil pressure switch supplying the ground for the hour meter (blue wire) pick up a new oil pressure switch and no change, works unplugged from the harness. I have an orange wire carrying battery voltage to the meter when switch in on, the blue wire is to supply the ground after the engine is started thru the green wire, I have continuity from the blue wire on the meter to the green wire on the pressure as I should, but with engine started hour meter does nothing, any ideas, am I over looking something, thanks for reading my post
