hour meter not working !!!
mouses911
hi everyone just bought a used Dixon dx260 and the hour meter doesn't work after replacing the hour meter and didn't fix it I did some research and started going through trouble shooting to figure out what's wrong. in this diagram I started from the Timer circuit and when I get to T-4 with the blades on and brake disengaged I only get like a random .14 volts or less should this circuit be 12v also. even so it doesn't appear to have anything to do with the hour meter actually not working. any help would be appreciated
View attachment diagram.pdf
7394
On Toro Z, the hour meter only counts when you sit in the seat with it running.
Of course you should have some reading even with it off.
mouses911
Thanks for the reply ! Yes it doesnt come on at all
