Lawn Ranger Don
- Sep 13, 2022
- 48
My meter on my Toro stays on and my battery went dead after two years so I'm thinking it drain the battery since it wasn't used during the winter months..
The hour meter battery is not charged by running the engine.My meter on my Toro stays on and my battery went dead after two years so I'm thinking it drain the battery since it wasn't used during the winter months..
Do you use a battery tender? If you don't keep the battery charged, it will have a shorter life. Did you read the entire thread? There is a battery inside of the hour meter.My meter on my Toro stays on and my battery went dead after two years so I'm thinking it drain the battery since it wasn't used during the winter months..
Coin cells are usually lithium not silver. The better longest lasting coin cells are silver, you have to shop for silver if that is what you want. Many sizes are available either way.Simple answer. No the button (coin) cell batteries are usually not rechargeable and are usually Silver oxide type. When they reach the end of their life they simply die.
It draws so little power it is of no concern. My Scag stays on all the time as well.Should the hour meter turn off when my key is off on 2023 Ariens Ikon 918005 zero turn mower? Mine stays on and I'm concerned that may be weakening my battery.
dittoIt draws so little power it is of no concern. My Scag stays on all the time as well.
