This is what I use..
7394 Lawn Pro Joined Sep 5, 2014 Threads 90 Messages 5,157 Jan 18, 2023 / Hose end sprayer which will dilute a chemical and stream at least 30 ft. ? #11 This is what I use..
S SHB Active Member Joined Apr 22, 2018 Threads 6 Messages 58 Jan 18, 2023 / Hose end sprayer which will dilute a chemical and stream at least 30 ft. ? #12 I use a 25 gal sprayer on the back of my ATV, to will go 30’. Spray the house every fall for lady bugs with it. I have also used the following Chapin 1/4 gal. All Purpose Professional Sprayer, Plastic Tank, Foaming Spray Pattern, 40 psi Max Pressure G362D | Zoro Order Chapin 1/4 gal. All Purpose Professional Sprayer, Plastic Tank, Foaming Spray Pattern, 40 psi Max Pressure, G362D at Zoro.com. Great prices & free shipping on orders over $50 when you sign in or sign up for an account. www.zoro.com
