M macdoesit Member Sep 26, 2025 #71 shootinsteel said: When you get it fixed let us know what the problem was and did Lowes take care of it for you. Click to expand... I took it to JD, they said there was water in gas. They fixed it runs great. Water not under warranty.
T theoldwizard1 Active Member Oct 12, 2025 #72 Johner said: Most fuel problems will vanish if you use a fuel conditioner added when you fill a new can. I do this all year long with a marine grade conditioner. A few penny's at this point will lesson the amount of aspirin needed. Click to expand... Even simpler ! Run the carb dry EVERYTIME ! Then you can use E10 !!!
A Auto Doc's Lawn Addict Oct 12, 2025 #73 macdoesit said: I took it to JD, they said there was water in gas. They fixed it runs great. Water not under warranty. Click to expand... Read my reply #4. Sorry it happened to you.
